Sudden screen glitches & freezes, requiring force restart
Hello!
My 2012 MacBook Air (I have the 2.0 GHz dual i7 + 8 GB of RAM model) has, for the last few months, started crashing at random, requiring a force restart.
Out of nowhere, the screen gets glitchy ~ you can see what was there, but its colors & shapes distort. If any audio was playing, it also becomes just a glitchy (loud!) mess. The only solution is to hold down the power switch for 10 seconds and force a restart. Or sometimes it restarts on its own after a few seconds.
The troubleshooting I’ve done:
1) installed a clean OS (Mojave) on a separate partition. Still happens.
2) happens on both battery & two different AC power adapters.
3) happens with & without external peripherals connected (powered USB3 hub, audio interface connected via firewire-thunderbold adapter).
4) I’ve reset PRAM & SMC. No help.
5) happens under heavy & light workloads, even sometimes sitting idle (i’ll return to my desk to find it has restarted itself).
6) sprayed compressed air inside all vents in case something was blocked by dust causing overheating. No help.
7) Ran Repair Disk in Disk Utility after starting up from recovery partition. No results.
What I haven’t done: replace the battery, which reports “Replace Soon”. I don’t want to throw big money at the machine if its logic board is about to die.
Any thoughts? The machine (aside from random crashes) still suits my needs perfectly, and I’d really like to not have to replace it.
Thanks in advance!
~ Peter in Athens
Update
Adding screenshots of CoconutBattery, per request!
좋은 질문 입니까?
댓글 6개
First I would install this app to see more clearly whats happening with your battery CoconutBattery past a snapshot of the main window so we can see it as well 기존 질문에 이미지 추가하기
Dan 의
I have the same issues with a fresh battery. The symptoms are exactly like described in the original post. Same computer. Very difficult to replicate as I’m not sure when it occurs. Have been keeping a log of circumstances under which this happens but there seems to be no red thread at all. I’m at loss over what other cause this could have.
DamianWinters 의
@damianwinters - Best to create a fresh question with your details
Dan 의
I am having the same exact issues on a 2012 MacBook Air. I was originally on Catalina, then I decided to do a fresh install of Mojave, everything looked fine, until I experienced the infamous screen glitching and restart.
My battery has been chanced 3 years ago, but I must admit it's been used quite a bit. In Sys Info shows 360 cycles.
Do you guys have any sort of update/solution found in the meantime?
Manuele 의
@manuele - Best to create a fresh question with your details
Dan 의
댓글 1개 더보기
