Home button doesn't work when installed in place
So on my iPad Pro, whenever I install the home button with the bracket and everything, it doesn’t work. But when I take both out and click it with my hand manually, then it works. How do I fix that? I thought it was pressure at first but when I install it, it doesn’t matter how hard I press on the bracket, I can’t get it to work. The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
좋은 질문 입니까?
댓글 5개
"Doens't work" is a vague description, we need more details: does the home button click when you press it? or it clicks but no response in the system? what about the touch ID?
Gorilla 의
Updated! The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
Taz 의
@taziamoma That is very odd, I never encountered this issue before, sorry :(
Gorilla 의
@sammyz me neither. I'm completely stumped. What do you think it could be?
Taz 의
@taziamoma My first thought is the pressure. But since you mentioned that was not the case, I'm baffled as to what the cause may be, let's get some input from @refectio
Gorilla 의
