주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
How do I keep my new digitizer from touching the LCD?
I followed your instructions for replacing the glass digitizer on my EVO 4G. Everything went great but a day later I noticed what looked like a bubble in the center of the screen. The bubble kept growing with use.
With a little investigation I realized it's being caused by the digitizer touching the LCD. If I pry up the edge of the glass a little it pulls away from the LCD and the "bubble" goes away.
While none of your current solutions come out and say it, it seams like it is important to have a good seal around the glass. Can you confirm this. I used dabs of cement at the top and bottom of the casing. Was that a mistake? Will one of those 3M EVO glass adhesive things fix this problem?
I'm about to change the glass on a friend's EVO and I'd like to avoid this problem on his.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Chad if you removed the adhesive on the first repair and only used glue then I'm sure that's your problem. The repair looks much like the iphone LCD/touch and they need the adhesive tape to stop a lot of the problems you mention.(Also stops the thing from falling off again-very handy! :-) )glue is a problem should you ever want to repair the screen again... you don't have to buy the exact evo adhesive, you can buy 3M double sided tape anywhere and cut it to size (annoying but doable)
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
You're right. I ordered a 3M adhesive strip, installed it a week ago, and haven't had any problems since.
Thanks.
댓글 달기
Very easy,remove the film that cover the LCD and !alas! bubles issue fixed.
Atagrasin
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,060
