주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Why can't my iPhone connect to any wifi networks?
I have an iphone 3GS. I don't use it with a phone plan; I was really just using it for the wifi apps. One day the wifi stopped working. It recognizes the wifi network but won't login anymore, not even to open networks including my own. I have reset everything, and erased everything including my own. I have reset everything, and erased everything several times. I bought a new sync cable and tried syncing it again. Still no luck.
My phone is not jailbroken and I have been hesitant to do that. Some forums have talked about it possibly being a problem with one of the updates in the software itself but I really don't understand how to go back to an older version of the software. My phone is not underwarranty.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Try these:
1. Go to General > Settings > Reset and press on Reset network settings.
2. Try to connect to some other Wifi network (Friend, coffee shop etc)
3. Try to disconnect your router and connect.
If non of them is working:
*then try restore via iTunes to the latest 4.3.3 Firmware.
*If restore doesn't work, then maybe the WIFI cable got disconnected from the board :/
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Emily 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 8
전체 시간: 41,649
