주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
iPad Air 1 Damaged Pads on Logic Board ( Will This Work? )
I have a iPad Air 1 with about 14 pulled pads, here what I have so far. Will this work?
The numbering might be incorrect. If I solder jumpers to these pins will this work? Please correct me if I'm wrong
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
It worked. I did as shown in the pictures I posted. It charges, has sound, syncs, e.g.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yay , good stuff mate glad you got that sorted ;)
댓글 달기
가장 유용한 답변
Not all pads necessarily need to be soldered to test points. Some can have shorter running jumpers from the pad you can see the circuitry traces. The ground pads aren't all required they can be skipped if needed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Yes sir that’ll get you back up and running.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tate A 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 665
