주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
USB & Bluetooth not working
So I have problem with this mid 2011 Mac Mini,
I know it is hardware problem 100% because I try to connect faulty printer, and there was electro-shock sound pop nothing special.
Everything was just right with Mac, but after few days It has a problem when I turn on Mac its says Bluetooth not connected and all USB ports provide power but doesn’t work, still mac boot to OS and it seems to be working just fine of course with team viewer.
After few restart USB and Bluetooth was working. But, after a month there was no way to get USB and Bluetooth working. I tried everything like resetting SMC and all those stuff.
I was thinking about replacing those two SMC USB controllers but I want to check anything else that may be a problem something in common with Bluetooth and those two SMC chips.
If anyone know something about that or can provide me schematics please help. Or, If anyone have this kind of problem lets together make this to work. This is a sad mac mini for now :)
Update (02/10/2019)
I just finished testing SMC chip, it has those 3V on input and also 3V on output between data + and -, what can be else… :(
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Have Your tied running on-board diagnostics? Restart your system and press the D Key to start it.
Mac startup key combinations
댓글 달기
답변 1개
Ouch! Your logic board got zapped!
The USB cable from your printer you plugged in has either a short within it to AC or you are using the wrong power brick for the device.
So what happens is the power surge into your computer damaged the logic board. Here’s the IFIXIT guide Mac mini Mid 2011 Logic Board Replacement and you’ll find the different logic boards listed. Presently IFIXIT is out of stock.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I do recommend you get a good surge suppressor and plug all of the devices into it to protect your system.
댓글 달기
답변을 추가하세요
Milan Milicevic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 274
