주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1698 질문 전체 보기
Disk drive not ejecting or receiving disks, will read though.
Hi guys!
Cleaned my 4yo PS4 the other day, but when I put it back together the disk drive isnt accepting or ejecting disks, it makes three quick beeps when pressing the eject button.
The only problem I had with the teardown was I broke the tabs on one of the ends of the ribbon cable going from the MB to the disks drive, but it's seated and the drive is reading this disks fine with manually put in.
Would that be the issue or have a missed something else?
Thanks in advanced!
Update (02/11/2019)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hello sir and good day,
try this remedy and let let me know:
The first step is to hold down the power button until the system beeps twice. Then wait about 30 seconds until all system lights are off, unplug the power cable, and leave it be for three minutes.
let me know if it works
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
Hi Daniel,
This has not worked unfortunately, what do you sugest next?
Have you confirmed the cables going from the motherboard to the optical drive are inserted properly and fully?
Can you also upload images of the tabs you broke off also
I have added photos into the original question
Replace the ribbon cable as that most likely is culprit . I would start there as it’s a cheap replacement and see if that’ll fix the issue
댓글 달기
귀하의 답변을 추가하세요
Stewart Mckenzie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 52
