주요 콘텐츠로 건너뛰기
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 질문 전체 보기
Screen doesn't work after dropping mug on rigt top corner of screen
My phone still partially works as I can hear notifications coming through, shutter noise when I turn it on, alarm still goes of and tapping noises when I touch the screen were buttons would be however at first there was just coloured blocks on my screen when I turned it on but now there is noting just black. I think there is a problem with connection between screen and motherboard-how do I fix it and how much is it likely to cost?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
If you truly believe it’s just a connection issue, try disconnecting your screen and reseating it. If this fails, you more than likely are going to need to replace your screen. The reseating will be free as long as you don’t break anything, but a new screen will probably be just shy of a hundred dollars. Heres the screen replacement (with frame):
OnePlus 5 Screen and Digitizer Assembly Replacement
the part:
OnePlus 5 Screen
OnePlus 5 Screen 이미지
상품
OnePlus 5 Screen
$79.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Sophie MacDonald 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 9
전체 시간: 200
