Can you fix the permenant cable to the VR headset
Dog chewed the cable from the VR Processing unit to my headset.
Pretty straight forward with no solid answer on how to fix it while keeping the longevity of the unit intact.
좋은 질문 입니까?
좋은 질문 입니까?
Hi
At the moment the I think the best thing to do is cut both cables back to a good looking part on both sides the strip the wires of their outer coating leaving just the coloured wires behind
Then I would try and figure out that wires how where(eg red to red or blue to blue)then solder them back together accordingly
To finish it off it would isolate each wire in electrical tape and put some form of shrink wrap over it to seal it up
Hopefully this helps
Any questions please ask
해당 답변은 도움이 되었습니까?
@hellomacos im going to be taking my headset apart soon. I have not be able to get ahold of Sony at all about resolution for this issue. Even making a ticket for repair seems to be and endless loop of clicking the same buttons never able to submit anything
From my understanding it’s just two separate hdmi Input/output
I’ll maybe add a guide for it if I can figure it out
@hellomacos hey. So I’ve gotten the casing apart and the wires separated. Pretty interesting
These are the important notes so far
The connector to the motherboard I did t expose all the way but from the “tear down” guide. It seems to come apart one more time? Not sure, it’s a small connector that plugs in up and down not in and out
. After further investigation. I see that it does not. Also I discovered that some of the metal I thought was insulation. Was actually a wire. That’s good news lol.
21-22 wires
I may need to micro solder the wires back together and re insulate wrap and shrink cover it I don’t see myself throwing any caps on these small wires.
Any suggestions?
@hellomacos i just realized that’s exactly what you said to do lol!!!
Here is a better photo I actually took it apart more slowly this time. 2 sets of 2 wires are wrapped separately. 1 bundle of wires is wrapped separately. And the more metallic looking wires are exposed.
Here is a photo of the soldering workstation I purchased
I wasn’t able to do a reply and add photo
해당 답변은 도움이 되었습니까?
You could repair everything by soldering it back together but I wouldn’t recommend it unless you have some experience first
This will be quite time consuming so if you want you could buy a faulty VR and use it as a donor so you can get the cable that you need
Up to you though
If you need any more advice just ask:-)
Hey this actually is a spare vr I had
I got a few ps4 controllers that need joystick replacements
I got the recommended soldering kit for like 50$ I think to fix the controller. I may need a magnifying glass and a smaller tip or? Im not sure about miceosolder. So my need for suggestion. Is. Will the recommended soldering kid on the ps4 joystick controller replacement going to be ok to do this small level? Or do I need something smaller. Im. New. But idc if it’s ruined or not. This is my practice basically. That and the controllers of course.
24 시간 전: 7
7일 전: 30
30일 전: 169
전체 시간: 3,303
댓글 3개
Yeah I’ve had a vr headwear for almost 2 years that a dog chewed up, if the wires are soldered to the internal board you might be able to sweat all the wires and re solder them. I’m going to attempt to tear it down and see what it looks like, find a similar strand of wire in a harness already and try to re run the harness somehow. The wires are so small there does not seem to be any way to fix them individually m.
Chris Vienola 의
I watched a very good video on YouTube of someone actually replacing the cable with a new one, but I can't find any place that actually sells this cable. Most of the ps4vr headsets for sale on eBay sold "for parts only, not working" have the same problem - the cable is broken. Does anyone know where to buy the cable?
Shannon Forsyth 의
Has anyone found a source for PSVR2 cables - they have a non standard USB-C like connector on the headset end. Or if anyone has a wire color to pin on the standard USB-C free end, I would be most appreciative! I have a USB-C 3 breakout board I can work with if I know what wire color goes with what function. Worse case I will have to go through the pins one by one (if I work this out, I'll post it here.)
lrshapiro 의
