주요 콘텐츠로 건너뛰기
AirPort Extreme 베이스 스테이션과 함께 출시된 이 하드 드라이브 장착형 제품은 Time Capsule NAS에 802.11ac 속도를 제공합니다.
56 질문 전체 보기
I can no longer access the 3GB drive anymore how do I open it
I can no longer access the 3GB drive in the Time Capsule. The WiFi router is still working OK and the Time capsule is listed in the left column of finder windows but when I try to connect to the drive via WiFi or Ethernet I just get a message that there is a problem connecting. I want to try removing the drive to test it separately to try to save the data and maybe replace the drive but…
How do I open the time capsule?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
It’s pretty easy, you just open up the bottom, disconnect some cords, and pull it out (basically). iFixit has a guide with full details you can follow.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Do keep in mind the drives format is unique to the TC (it is not natively mac readable). If you really need to save the data you'll need to transfer to another A1470 capsule. Thats assuming the drive is still good.
Your other option is to use a data recovery app like Stelalr
Often times the power supplies go
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
frank 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 119
