주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Screen won't close tight after display replacement
I replaced new display for iPhone 7 by LCD Screen and Digitizer Full Assembly Fix Kit and I have no problem during repairing steps where I applied new display adhesive.
Now I have problem when I close device that is a gap between the display and rear case, exactly on bottom right corne and on half bottom of right side.
What do yo suggest me ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 답변
I found out problem! It’s problem with new display, I tried to assembly again the old display and It closes tight.
There is IC cent to display flat and It’s not aligned, infact bump into metal shield of rear case.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hi
Perhaps your phone frame is bent, because of this skew the screen does not sit tight to the frame
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same problem for mine, and I think it might be that the battery bracket may be pushing up on the screen. My battery bracket was popping up on one side while the other was screwed down and I had trouble screwing both of the the tiny screws in without one popping out. This causes the entire battery bracket to sit at and upward angle and apply pressure on to my screen. This may not be your exact problem but it is worth a try to see if that could be it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
it will be the small rectangular heatshield on the back of the new screen not alignet correctly, there is a recess on the loud speaker it has to sit in.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
strange thing is the old lcd sits down correctly, what do you think? It's design flaw?
댓글 달기
I tried everything on mine and it ended up being that the back was slightly bent. I bent it back into shape gently and resolved the issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
omg i had the exact problem and thank you i wouldnt think the frame would be bent now i know the actual reason
댓글 달기
귀하의 답변을 추가하세요
Riccardo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 2,003
