주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
330 질문 전체 보기
I need to replace this board but have no info on it
This board got wet and is corroded and I need to replace it but can find no info on it or part number. I don’t really want to have to buy a whole upper case to get one. Does anyone know what it’s called or have a part number for it or where to get one?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
가장 유용한 답변
@mayer - is this what you need? MacBook Pro 15" Retina (Mid 2015) Trackpad. Click on the right image.
MacBook Pro 15" Retina (Mid 2015) Trackpad 이미지
상품
$89.99
해당 답변은 도움이 되었습니까?
점수 1
댓글:
@danj looks to me like this board is attached to the trackpad. If I can just replace that board, the job turns into ten minutes instead of two hours and risking destroying the battery.
의 답변
As long as the trackpad its self is OK that should do it!
의 답변
Aren't the two cables soldered from trackpad to that board?
의 답변
@danj is @ben correct, are they soldered? I need to get this repair done today.
의 답변
I've never tried taking it off. I would first try the bad unit to see if you can disconnect them.
의 답변
의견 추가하세요
The board comes with the trackpad, it’s the controller of the force touch, you see those two flats are soldered.
It’s a mess to desolder, they melt too quickly, i tried is a nightmare..
Can you not just unglue the middle bit of battery cells and take out the trackpad?
Emil
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Looks like it can’t be done. After the board is unglued and lifted up there are ribbon cables (the clear ones)that run onto the trackpad that can’t be disconnected at the board. Will update later after I have full access to the trackpad
@danj
해당 답변은 도움이 되었습니까?
점수 0
댓글:
@mayer - Bummer ;-{
I thought the black cables is all you needed to undo.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
mayer 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 58
