Why doesn't it turn on
When pressing the power buttton; the machine will not turn on or boot up.
좋은 질문 입니까?
좋은 질문 입니까?
One easy check is the charger. Chargers normally come with a green light. If it has it and won't light up, then that's your problem. If it doesn't have this indicator, then you will need a multimeter to test for voltages. This is the most common problem with laptops. If after testing your charger, your computer still doesn't work, then you'll need to take your computer apart and check some objects on your motherboard, normally what pops is the voltage regulator called MOSFET.
해당 답변은 도움이 되었습니까?
First you should determine if the system will work off the battery. Install a fully charged battery from another D610 and see if it will boot. If so, then let windows load completely to the desktop and plug in the charger. The power indicator in the lower right should indicate on AC if the power adapter/charger is functioning. If you do not have a power indicater, you can look at the function by going to control panel and opening the Power Options icon and clicking the power meter tab to view if your system is working on AC power on not. If not then the adapter is suspect and should be replaced.
If the new adapter doesn't fix the problem your AC jack on the motherboard may need to be replaced and should be checked by someone that does quality repair work..
I hope that helps, Good luck
해당 답변은 도움이 되었습니까?
This may because that the button array isn't work. What im talking is about the sound and power button circut
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 5
30일 전: 7
전체 시간: 4,226
댓글 2개
I have a Dell Latitude 6430u. With the power lead in, it doesn't turn on - power light comes on fraction of section and then goes off. With the power lead out i) the battery charges and ii) it powers on no problem. Once it has booted on the battery I can plug the charger in and it keeps the battery at 100%. Any ideas?
Ian Goodyer 의
My one DELL d610 laptop but not be open this power please help
farukahmed1234513 의
