The right earphone do not play sound but left is OK
What can I do?
Thanks
좋은 질문 입니까?
Gonzalo, take a can of keyboard air cleaner, you can buy those at any dept store. the ones you get to clean your keyboard etc. Hold your ipod upside down and blow a few puffs of compressed air into it. Take your headphones and plug it in and out a few times in succession, since this may free the stuck contact. If that should not work for you, you will have to replace the headphone jack. Good Luck
해당 답변은 도움이 되었습니까?
Before taking the device apart, you should try it with another set of earphones, just to make sure that the problem is actually with the device as opposed to the earphones.
해당 답변은 도움이 되었습니까?
i have this problem on my gen 1 nano, try and get a replacement jack, i did read that the part is mechanical so you could try cleaning it with a cotton wool bud and see if that helps, hope this works
해당 답변은 도움이 되었습니까?
I have tried with another earphones and I have the same problem.
해당 답변은 도움이 되었습니까?
Ya, there is something probably wrong with either the jack or the logic board, then.
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 910
