Install OS X
How do you install OS X on a new hard drive? I've tried holding down the "C" key, nothing happens except the B&W apple screen with a spinning circle. When holding down the"option" key a window comes up showing me the OS disc, a reload arrow and a continue arrow. When I click on the disc, nothing happens, but when I click on the continue arrow, it goes back to the B&W apple screen with the spinning circle.
I am using disc 1 which I take is the restore dics. All I get is the spinning thinking circle. With a new HDD, would a firmware password still be enabled? If so, what is the process to get the OS onto this new HDD?
좋은 질문 입니까?
댓글 2개
suggestion - you should keep all your posts on this issue in a single post, rather than starting a new question each time. I see your slightly earlier post here: Reload OSX
note: you can always edit your existing posts!
bac 의
What happens if you just wait for the apple logo with the spinning circle? Does it boot into the normal os or does it boot into the installer?
Sterling Hirsh 의
