What is the display connector part on a late-2015 iMac?
I have a late-2015 iMac 5k with a broken display. It looks like the previous owner broke a couple pins on the logic board connector based on the couple missing pins on the original LVDS cable. Even when I connect a working display using a new cable it doesn’t function.
It’s not the display or the cable as I’ve tried both on another iMac 5K.
I’ve seen this (the logic board connector) referred to as a LVDS or a special eDP connector.
*Where can I buy this? And can I find someone to solder/replace it for me?
I’ve also tried reseating the cables with no luck. Is there something else I could try?
It’s one of the i7 models with m395x. I’d hate to junk it.
좋은 질문 입니까?
댓글 6개
@dieselm if you can give you your Mac Model No. or SN I can link you to the replacement Logic Board.
Alex Robinson 의
I'm going to take a wild guess and say its an A1419 "Core i7" 4.0 27-Inch. If this is the case, here's the part:
iMac Intel 27" EMC 2806 Logic Board
Alex Robinson 의
I'd rather not replace the whole logic board. Can anyone identify the connector part on the logic board?
Diesel mcfadden 의
Don't guess! Look on the bottom of the stand, get the serial number, plug it in here and tell us EXACTY what machine you have. We can then better advise you.
https://everymac.com/ultimate-mac-lookup...
mayer 의
emc 2834, a1419. iMac 17,1
Diesel mcfadden 의
댓글 1개 더보기
