Do I still have a problem?
I had a problem with my 90 series Kenmore washer knocking loudly in spin cycle. With a burn smell to go along with that. I did some research then replaced the trany, clutch and coupling. Everything seems to be working but I have a question. Because of a loud pump I watched the cycle and don’t remember if during the drain cycle it should also spin. If I open the lid during draining I see it is not spinning but if I press down the door switch it will start spinning. If I leave it alone it will drain then after that spin. Can someone tell me if I still have a clutch problem or is it good. Thank you
Update (03/03/2019)
Oldturkey03, thanks for the response. I’m going this route because when I comment to your response I get a message that my comment is kicked out as spam.
The model of my Kenmore 90 series washer is 110.26914691.
Thank you.
좋은 질문 입니까?
댓글 1개
@griegox this "it will drain then after that spin" is actually right. Does your laundry still drip water extensively after the washer stops?
oldturkey03 의
