주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
Reboot when i'm calling
When the dock connector is connected, it will restart.
I changed the dock connetor, but it not good.
What is the problem? :S
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
I may have a problem with the battery. (Really doubt that it’s the battery) it probably needs logicboard repair.
It sounds like you either need a replacement earpiece speaker or top components flex cable replaced. If the earpiece is not connected properly, any time it attempts to make sound through that speaker, it restarts the device. Should be as easy as top flex cable and earpiece replacement.
There have been a lot of problems with the dock connectors. Does it do that with a regular iPhone charger?
댓글 달기
답변 1개
가장 유용한 답변
Front camera cable must have been ripped, this would be a fault caused by the proximity sensor somehow being damaged. See if it reboots with front camera disconnected.
Siri also uses proximity sensor so see if it reboots when you try to run Siri.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
ttdarabant 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 211
