주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2086 질문 전체 보기
Why is my battery draining to quickly?
Had to replace the screen on my iPhone 6S and purchased a replacement from here. Now if I use any application that requires connecting to the internet, my battery drains in minutes. It charges fine and using the phone or any application that doesn’t require the internet will last most of the day, but any function that requires an internet connection drains the battery in minutes. Playing Candy Crush starting with a full charge last about 15 minutes!
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
3개의 답변
가장 유용한 답변
Seems like your battery needs to be replaced. Check your battery health by going ti Settings/Battery/Battery health.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I agree with Scott P. Have you made sure the battery is to its full functioning capacity??? To this go to settings on your phone and click on “battery” once there click on “battery health” your battery should read like this (look at the picture) if it says anything else you more than likely bought a faulty battery and may need a new one. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
To Scott P. and wm_alvarez,
First, thanks for responding my question so quickly . My screen currently reads ‘Maximum Capacity” at 80% but, that leads me to still ask the original question. Before I broke my screen and had it repaired, my battery capacity was at 89% and the phone lasted at least 8 hours no matter what application I used. Logically I understand that at 80% the battery will hold a smaller charge and thus seem to lose power quicker because there is less power to be had, but if it lasted 6 to 8 hours at 89%, I don’t understand why it only last 15 minutes at 80%. It just doesn’t seem right but thank you for the information and I’ll get the battery checked.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Darlean Youmans 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 22
