home button with third party screen replacement
does replacing iPhone 7 screens with third party screen replacements still cause the home button to not work?
좋은 질문 입니까?
좋은 질문 입니까?
Well, if you used a home button that didn’t come with the device, it will only function for the ‘click,’ not the Touch ID part of the button, only Apple can do this and still maintain Touch ID function.
해당 답변은 도움이 되었습니까?
This is not true on the iPhone 7 and 8, you're thinking of 5s-6s. Neither the home click nor Touch ID will be functional with a non-original home button on a 7.
I don’t know why people are saying it will continue to work, just without Touch ID. On the iPhone 7 and 8 series, if you replace the screen and don’t replace the home button with the original button, all home button functionality will be lost.
Edit: okay, there are some interesting replacement flex cables that kind of work, but in my experience they’re pretty cheap feeling and kinda finnicky, not to mention a fairly difficult repair relative to just a screen replacement.
해당 답변은 도움이 되었습니까?
If you move the home button from your original screen to the replacement screen, everything about the home button will work.
If your replacement screen includes a new home button and you don’t replace it with the home button from your original screen, everything about the home button will work except Touch ID.
해당 답변은 도움이 되었습니까?
so it will work with third-party screens and my home button?
Yes it causes it to not work because apple made to where it has to still have original home button or be fixed at their store. This was made to create it more difficult for us 3rd party repairers and it started with the iPhone 7.
해당 답변은 도움이 되었습니까?
Yes their is a possibility that the new screen you replaced has problem on it, i have that issue before.
Did you try to put back your old screen and home button if its still work?
해당 답변은 도움이 되었습니까?
yes it still works
If your home button work with your old lcd that means the new lcd is bad possible issue is either on lcd flex connection .
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 465
