주요 콘텐츠로 건너뛰기
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
37 질문 전체 보기
Phone is not turning on. It just vibrating when I used to turn on. Bu
My phone got switched off. And now its not turning on. When I used to turn it on, its just vibrating and showing white display with android one. But not turning on. What should I do....
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
My mi a2 is a year old and the display keeps turning on and off. Even so I get to feel vibrations when I press the power button or when messages come in. The mobile rings as well when I dial my number from another mobile. Planning to take it to a sevice centre.
댓글 달기
답변 1개
You can try if the “recovery“ works.
  1. Hold Power & Volume Up until the screen shuts off
  2. Release both buttons and immediately press and hold them again
  3. Retry until you can see the “No command“ screen
  4. Just press them both a the same time once and for the least
There should be some options to choose from with:
  • Volume UP/DOWN
  • POWER to select
From here you can try to factory reset the phone which erases all user-data but can get rid of many problems…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
yogeswarireddy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 136
전체 시간: 2,256
