주요 콘텐츠로 건너뛰기
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
48 질문 전체 보기
Is there an extension cable for the battery connection
I use my mi5 as a flight instrument. I want to get a bigger battery directly connected to the motherboard. Xiaomi do have bigger batteries but the connection cable isn't in quite the right place
I want to buy i.e. Mi max battery and buy an extension for the connection.
There's no back on the phone, size not important.
I don't even know what the connection is called.
Cheers
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Probably cheaper and easier to just buy a power brick and a USB extension
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is on my paragliding flight deck and unfortunately what happens is the cable breaks, the phone USB breaks or the batteries USB breaks. They've all happen to me before .
I really need it connected at the rear of the phone with an extension or directly to the board.
Thanks though
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
hmmm, maybe you can make a homemade case with either as 3d printer that could support both? or a bunch of ducttape plastic. ) ziplock container, with a hole cut for the screen, taped to the container, and the battery pack also in the container and all sealed up, idk. best of luck!
Thanks Dan, I've also been down that path before. I really want to do it this way. Cheers
댓글 달기
귀하의 답변을 추가하세요
Jaded b 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 84
