주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2261 질문 전체 보기
iPhone 7 static noise from bottom microphone
Hello,
I have an iphone 7 and apparently the bottom mic is recording just static noise and nothing else when recorded with the voice memo apple inbuilt app and other sound recording applications from the store.
The front and the rear mic works perfectly, so normal calling works perfect as well as with siri.
But certain apps such as whatsapp, hangouts, duo, during a normal call the other person can't hear anything but when put on  speaker they can.
I have used an application (rec lite) which lets u record voice from all the 3 in built mics individually and the bottom one seems to be the issue (only static noise being recorded).
Could you please tell me what the problem would be and how could i get it fixed?
Thank you so much
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I also have the same problem and I don't know how to fix it?!
댓글 달기
답변 2개
선택된 답변
The bottom microphone is on the Lightning Flex. You can replace this yourself by following this guide.
해당 답변은 도움이 되었습니까?
점수 3
댓글 13개:
Will replacing the connector solve the problem? Or Does it look like an audio ic issue?
doubt its audio ic or it normally says recording failed.
thank you chris, i'm still waiting for the whole adapter to arrive. I'll replace it and update if it fixes it.
Static is not a typical symptom of an Audio IC issue.
i took it to a local repair shop and they said, they will try replacing some kind of belt?
Do you think that might help the case?
Or is it more of the whole lightning port with microphone adapter issue?
댓글 8개 더보기
댓글 달기
same problem i phone 7. Normal voice call work with and without loudspeaker. Video recording too(front e rear work perfect). Problems come out with memo voice app(hissing sound) and whatsapp call, with loudspeaker on it’s ok, normal whatsapp call they cant hear me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jack Helson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 27
전체 시간: 15,543
