주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
My Ipad Air Won't Boot Up
I bought the I pad 2nd hand over a year ago with no issues however the screen had been replaced. Last week after an overnight charge the ipad wouldn’t boot up. I opened it up to find a screw that had held the screen in place had worked itself loose and resting across the bare terminals of the charging socket. Where do I start or do I simply bin it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
No don’t through it away you should replace the charging socket.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Cheers Scott, for £2.99 its definitely worth a go
Scott, the Lightning Port requires micro-soldering so it is not a trivial replacement. The vast majority of DIY fixers don't have the experience or tools to do this kind of repair so you should always point that out so people don't order parts they won't be able to use or get involved in a repair they can't complete.
Ok thanks for that info.
댓글 달기
귀하의 답변을 추가하세요
Alan Jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 40
