주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
621 질문 전체 보기
Need to find the right Logic board
Hi,
I want replace the logic board on this macbook. But not sure of the correct part number. My niece spilled coffee on the keyboard and it never powered on after that.
Model is MQD42LL/A (A1466). 13.3”/1.8GHz/8GB/256GB.
Can anyone guide me what the correct part for the logic board of this macbook?
(btw, not sure if it is early 2015, I just selected it)
Thanks,
Ali
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Technically you have a 2017 system: 13" MacBook Air 1.8 GHz Core i5
The logic board is physically the same as the older 2015, Apple populated it with a slightly faster CPU as the Intel stopped producing the older version.
Thanks arbaman & Dan for your replies.
댓글 달기
답변 2개
선택된 답변
There’s no need to buy a board with exactly the same specs as your old one, you might choose between other compatible ones or even upgrade, but it’s essential you have exactly the same board model. You’ll find a code on the board itself reading as 820-xxxx-x (820-3437-A probably). With that number available you won’r run the risk of a wrong purchase.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@ali2019 - Review the IFIXIT guide here: MacBook Air 13" Early 2015 Logic Board Replacement. IFIXIT lists the boards with their Apple P/N’s which is the best way to get a compatible board.
Here’s one source for your board MacBook Air 13.3" 1.8 GHz Logic Board, i5, 8GB, Mid 2017 - Apple P/N 661-08140
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ali2019 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 507
