주요 콘텐츠로 건너뛰기
더 커진 Samsung의 열 번째 주력 핸드폰 버전, 2019년 2월 출시. Android 9.0 (Pie)와 함께 제공됩니다.
107 질문 전체 보기
From whee I can buy the back panel for galaxy s10 plus?
i want to buy the back panel for galaxy s10 plus cuz i broke mine .
and onther q . if i replace it . is the water resistant will go away ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
As far as I know, there aren’t currently any replacement glass casings on the market. It’s a very new phone! You’ll just have to be patient for suppliers to get some stock, and maybe consider a case…
It most likely won’t be water resistant after a replacement, but if it’s cracked it definitely isn’t water resistant anymore anyways.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
ubreakifix seems like they have parts in stock. Not something you can do yourself but if you need it fixed, definitely an option.
You can replace the back glass yourself, but remember, heat is your best friend! totally not something that jerryrigerverything said ;p
We have guides for the procedure! Follow this guide: Samsung Galaxy S10+ Back Cover Replacement
댓글 달기
Mobile Defenders has the back glass.
It will become less water resistant depending on the type of adhesive and type of way you seal up the back.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you can buy a LUVSS back glass from amazon with camera lens and full set tools kit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
molhamstar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,989
