주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
Why is my iPhone in a boot loop and then goes in to a red screen
How do I fix my iPhone5s that is in a boot loop and then goes to a red screen and then goes back to the apple logo and it has to be plugged in to event turn on
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Could be many things, can be caused by:
  • Bad front camera assembly, perhaps cable got torn after drop, if unplugging cable lets the phone boot that is the case
  • Bad Tristar / charging chip, can happen can be confirmed if apple logo does not appear with charger plugged in and battery unplugged. Will require someone with micro-soldering experience to replace chip on board.
  • Corrupt Firmware / Software restore will fix this
  • Bad CPU / NAND / Baseband = Unfixable pretty much.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Are the replacement logic borders from ifixit good ?
댓글 달기
Has the screen been replaced? This could be something like ''Long Screw Damage''
Try to put it in recovery mode and update it, it might give you an error code that gives you some clue.
Also, what is the history? what’s happened for the device to be in the condition it is in?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I don’t know if the screen has been replaced but it stoped working when I dropped it but the highs was not that high
The error is a error 3014
댓글 달기
귀하의 답변을 추가하세요
Jayden 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 85
