주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
iPhone 7 P Wont charge when phone is sleeping
Had a iphone 7 plus come in for no power, replaced tristar and it powers now but wont charge when the phone is sleeping. Has a steady 1amp pull while booting to lock screen, the moment the screen goes black, power draw falls to 0. If i wake it power draw is around 0.3a.
Tried a second tristar, replaced tigris and q2101 next to it, new charge port and battery with no change.
Hoping someone has either seen this or can point me in the right direction what to check next.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Try another battery and check battery connector. A bad connection to battery can cause this weird behaviour. I had it happen in a iPad air 2 before.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks, I did check that and they seem ok. I think its gonna be the signal from the big power ic to tigris. I did audio ic repair on this phone about a year and baseband repair couple months after so the traces in the board may be just failing.
Took another stab at the phone after all this time, the battery was damaging the connectors. So I had to replace the connector and battery. All good now.
댓글 달기
Ben is right, try the battery connector. It might also be that you need a new charging port.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
joel rakich 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 78
