Which are the reasons for a MagSafe LED to start blinking (randomly)?
Hi! A few days ago the MagSafe connector stoped turning its LED on, and with that, it stopped charging the battery. The computer can still be used with the adapter plugged-in (from the menu-bar: “Battery not charging”, “Power source: Power Adapter”) and it works as usual, it’s just the battery that doesn’t charge. Once in a while the connectors LED may turn non, charge for a bit, and then back off, following what seems a random pattern. If its fully charged, it may be green for a while, and otherwise it turns orange.
I’ve already cleaned the Magsafe connector both on the adapter and on the side of the computer (more than once, following Apples instructions) and reset the SMC more than once too. The adapter has been the same since I bought the machine and the battery too (reaching about 2000 cycles right now, way past the maximum recommended). I was wondering if there was anything else I could try before buying a new adapter and/or battery.
There aren’t any Apple Stores in my country, so checking with them is not an option, but if I find someone with a MacBook with the same adapter (85w) will try to see if it works with mine to start discarding other things as the problem.
Huge thanks in advance!
Agustin.
좋은 질문 입니까?
