My iPhone Front Cam Mic and rear mic not working
Hi I Need Your Help My Front And Rear Mic Not Working Theres Is A Possible Way To Fix This? Help!
좋은 질문 입니까?
좋은 질문 입니까?
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
Make sure you update your device to the latest version of iOS and then try to isolate which microphone is not working properly by trying each individual microphone with the related apps above. Check the microphone port holes for dust and debris which could be attenuating the sound.
If the issue affects more than one microphone, then it could be the Audio Codec IC on the logic board. Anything at the logic board level will require micro-soldering so you would need to find a repair shop that offers those services.
해당 답변은 도움이 되었습니까?
I did all the thing they tell us in the articles , but instead of that it’s didn’t work
so I want my back microphone as front microphone
cause Siri is not listening to me
so what should I do now
해당 답변은 도움이 되었습니까?
I have a similar problem with my iPhone XR. When using the camera app the sound in the videos cuts out or is not audible at all. Sometimes I just hear a hiss. When tapping the phone those sounds are heard though.
I used the Filmic Pro app that allows you to select the input mic and it appears to be a faulty backside mic. Front and side mic seem to work OK. I guess It’ll need to be opened up to fix this.
Any tips?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,680
댓글 2개
Was the device water damaged? Or maybe did a drop break the microphones? In that case it could be a motherboard
Jakob Kenley 의
Yeah i agree
Dino David 의
