주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Top of touch screen won't respond to touch after screen replacement
I recently replaced the whole display of my iPhone 6S plus with the ifixit kit. I tested the touch functionality before sealing it up and everything seemed to be working fine. But as it turns out, the top 10% of my screen won’t respond to touch. So I can’t swipe down to get to notifications or use the Back Menu buttons in my applications.
I’m pretty sure I’ve got all of the connectors for the digitizer seated properly but I could be wrong. The rest of the screen works well and it’s just that top 10% that doesn’t respond.
Before opening it up again to check the connections, I wanted to see if there were any specific reasons why only the top of the screen wouldn’t be functioning. Hopefully that clue will give us a better idea where to start.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Usually it's either a faulty screen or connectors on the board and screen need to be cleaned. You can use isopropyl alcohol and a brush to clean both connectors. Sometimes dust in the connector stops the screen from having a good connection.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Allan Lam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 53
