Where can you buy a coaxial connector for Jensen tv
where can you buy parts for a Jensen TV/ coaxial connector
좋은 질문 입니까?
좋은 질문 입니까?
You should be able to get replacement components from Mouser.
해당 답변은 도움이 되었습니까?
This helped out a lot because everyone else wasn't showing the part I needed
Hi,
What is the model number of the TV?
Are you asking about the antenna input coax connector located at the back of the TV?
If so you may have a problem.
On most TVs the coax connector is part of and is connected directly into the tuner module which is a factory sealed unit.
The module is usually mounted directly onto the mainboard or an input board.
You can cause more problems than what you had if you try to open the module to replace the connector.
A better option is to source either a replacement tuner module or a working replacement mainboard (or input board).
Search online using the tuner module part number or the board part number to hopefully get results of suppliers.
If you can’t locate one or the other then a workaround is to connect the antenna to a digital set top box which connects to the TV either via HDMI or Component or Composite video connections
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 54
