주요 콘텐츠로 건너뛰기
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
81 질문 전체 보기
What does the ( h) code mean on my refrigerator
What does the ( h) code mean on my refrigerator 2013 Frigidaire side by side my refrigerator isn't getting cold enough on the fridge side
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I have this same problem. Repair guy has been out 3 times & its still doing it. My coils are spotless. I always keep them clean. There's hardly any air flow thru the vent from my freezer to my fridge. He said he fixed it. But yet its still doing it He supposedly replaced the sensor as well.
@kimgossett
What is the make and model number of your refrigerator?
댓글 달기
답변 2개
선택된 답변
It’s an alarm for high temperature. You can push the temperature setting and it should go off, but it will come back as long as the tempature is too high. Try cleaning the coils under the refrigerator. You can refer to your owners manual for what regular maintenance needs to be done to keep your refrigerator cooling properly.
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
What if that doesn’t work
댓글 달기
A friend said it was the air damper so I replaced it but it’s still doing it
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You’d need to check the temperature.
Clean condenser coils.
Check the evaporator fan and condenser fan, they should be running when the compressor is running.
Check for ice/frost forming on rear wall .
댓글 달기
귀하의 답변을 추가하세요
Macleon Warren 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 12
7일 전: 68
30일 전: 258
전체 시간: 43,319
