Black screen while booting after replacing fusion Hd with ssd
After carefully removing screen and replacing the fusion with a mercury ssd, the iMac boots with a black screen and takes five minutes to get to sign in screen. Thereafter it works perfectly. I tried booting from and external ssd drive with clean Mojave os, with same result. After the iMac runs for an hour or so and is shut down, I can reboot with same black screen but only takes a minute to reach sign in. Any suggestions!
좋은 질문 입니까?
댓글 4개
Did you pull both drives?
The SATA HDD & the blade PCIe SSD on the other side of the logic board.
Dan 의
I don’t think the late 2012 has a PCie blade ssd. The iMac had a fusion drive which supposedly has a built in ssd and spinning drive combo
Jabrain 의
A Fusion Drive is physically two drives! In this series two SATA based drives. In the newer models you have a SATA HDD and a blade PICe/NMVe.
Dan 의
@capeparadise you were able to solve this problem you have, I have the same problem as you, I would appreciate any information
francis 의
