주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
361 질문 전체 보기
iMac 27 late 2015 CPU upgrade with i7-6700?
I know you can upgrade the late 2015 iMac 27 with the i7-6700K. But I can get a i7-6700 for much cheaper that the i7-6700K.
Has anyone tried it?
Thanks
p.s. I know the iMac is difficult to open. Already did it many times before.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
If you already went through the very stressful process of opening and disassembling the unit the CPU replacement shouldn't be a problem. I did it myself though I've used the 6700K - can't see why the 6700 wouldn't work after al my unit had the 6600 (not the unlocked K).
One thing though: the spring that holds the heatsink in place can be a very difficult thing to put back and maybe even damage your CPU - ANY CPU if you're not careful enough.
I recommend ‘flatten’ it a bit using a plier or whatever you can. It should still work as to hold the heatsink in place but if it is too strong that you have to push down very hard (and I am quite a strong person…) you should definitely ‘flatten’ it or you WILL damage you CPU. Check the CPU replacement guide and read the comments on step 62 - you'll see I'm not the only one who had a problem with that:
iMac Intel 27" Retina 5K Display CPU Replacement
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
mollocampo 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 83
전체 시간: 1,138
