주요 콘텐츠로 건너뛰기
Power Mac G5 Late 2005는 10월에 소개되었으며 다음 해 8월에 단종되었습니다. 2.0 GHz 듀얼 코어 프로세서, 2.3 GHz 듀얼 코어 모델 번호 A1177, 그리고 2.5 GHz의 듀얼 코어 듀얼 프로세서 (쿼드 코어)의 세 가지 구성 옵션이 있습니다.
26 질문 전체 보기
Will not boot to OS
My power mac A1117 powers on, fans run but no boot tone and no image on screen. Removed RAM, Removed Graphics card, Removed Battery, removed hard drive,Pressed switch in on motherboard for 30 secs. TNA. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
If you shine a flashlight on the screen can you see anything? Also have you tried a PRAM reset?
댓글 달기
답변 1개
선택된 해법
To reset the SMU on a Power Mac G5 (Late 2005) computer, either use the steps listed above for the Power Mac G5 (Late 2004) or:
Turn off the computer by selecting Shut Down from the Apple menu or by holding the power button until the computer turns off.
Open and remove both the metallic outer door and the inner plastic air deflector.
Remove the fan assembly immediately to the left of the processor module.
Press the SMU reset button on the logic board.
Replace the fan assembly, air deflector, and outer door.
Turn on the computer.
The SMU reset button is located underneath the lower bank of system memory slots.
Next look at the diagnostic lights on the logic board and tell us what they do when you try to start.
해당 답변은 도움이 되었습니까?
점수 3
2 댓글:
There are 2 lights on one red and one amber. I have tried an SMU reset. (between 2nd and 3rd dim slot)
Which lights?
댓글 달기
귀하의 답변을 추가하세요
david stather 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,073
