주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Why is my touch screen not working
I bought a iPhone 7 Plus and I bought it as faulty as the screen was not working, so when I received it I got the screen replaced it started working fully then I repaired it I replaced the back housing which involves switching the motherboard after the repair when installing the screen back on there was a bit of adhesive on the the gold circles on the motherboard next to where the screen goes so I scratched the adhesive off with a screwdriver after that I installed the screen and the touch stopped working the phone turns but the touch does not work is there anyway I can fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
“Scratching”, “Screwdriver” and “Logic Board” are not three words that go well together when it comes to iPhones :>).
I can’t really say I fully understand what you are referring to so perhaps you could add a picture to your post so that I can get a visual. However, I will say that based on your description, my fear is that you may have damaged the logic board. It could be a damaged connector or the tiny parts that surround the connectors. If you have a jewelers loupe or microscope (or just great young eyes!), take a closer look at the area you played around in to see if there is any signs of damage.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Since the touch isnt wokring can it be the touch ic that needs replacing
The Touch IC is embedded in the screen, not on the logic board.
What do you think the problem is and can it be fixed?
댓글 달기
It could have internal damage. Apple also likes to screw with you because they don’t like people fixing there stuff for a reasonable price. So Apple will at times make things stop working or malfunction. Maybe check everything is where it should be and maybe try again. Or maybe get a new screen and try again. Hope that helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I’ve tried 2 new screens both of them not working the touch is not working
I don't really know then. I'm really sorry, hope it all works out. Have a good day
댓글 달기
Was the adhesive u scraped just the black slimy stuff around the housing edges??
I think the first place to start would be to try a new screen, remember to carefully remove the original home button flex
As minho said touch screen controller is on the screen itself, u could have done some other damage to the board as well but cheapest easiest and most logical course would be to try another screen first :)
Obviously first check the connector for the screen is fully plugged in sometimes the longer connector which is for the actual screen itself doesn't plug fully/ in so check thats firmly in first before trying a new screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi I’ve tried new screens and still the touch is not working the adhesive was on the motherboard it was a little piece of black adhesive in between the connector, I don’t know what’s the problem I think it’s a motherboard problem
The adhesive u peeled off like a foam cushion around the connector, as uve peeled that uve probably knocked off a cap, resistor, filter or other ic off the board... really the best way forward is to check it properly under a microscope, try not to do anymore without having a look carefully under a scope as the ic and its pads might still be there poking it etc will just make it more awkward to repair
댓글 달기
귀하의 답변을 추가하세요
Phones repair 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 128
