pentium dual core t7500 saying revision not supported on laptops
I have a t7500 dual core processor that has a scratch on the side , but I dont believe the scratch is the problem, but whenever i install it on a laptop (i have tried it on three different ones but the other processors work fine ) and boot it to bios (all different versions) it says microde processor microde update failure
revision of processor not supported
i have not used it ever since and put it in a spare mobo
pls help
also I plan on using it if it works to switch it for a t4500 on a latitude e5500 so i could play tanki online with higher fps if the t7500 is fixed which would be better ( the e5500 uses a gma4500m graphics
좋은 질문 입니까?
Hi @fegelein3290
You can try booting up with the working processor first and try updating the BIOS to the latest version to test out.
Augustine 의
thanks augustine I will
Brayden S 의
