주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
iPhone 7 Bluetooth not working
Ive been given an iPhone 7 to replace my old SE. Everything works as it should except for the bluetooth. When you go into settings, instead of the Bluetooth On/Off switch there’s just a spinning disc.
I’ve been through all the troubleshooters to the point of restoring it back to factory defaults with the latest IOS, but it still doesn’t work.
However I have noticed that when I put the serial number into Apples website, it should be a different color than it is (Apple say it is rose gold, but it’s actually silver) so I guess at some point it has been re-cased.
Everything else on the phone works fine including the 4G and wireless. Can anyone suggest what might be the issue with it?
Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
All that I know of that could help is to reset or hard reset. I don’t know what to tell you other wise, that really sucks. If it still doesn’t work try contacting Apple’s Support team: https://support.apple.com/contact. Hope this works.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If it has been swapped into a different shell then it could be missing and antenna, if you were to open it and take a picture I maybe able to help.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I've added a picture of the inside, though I don't think it shows much...
Thanks.
댓글 달기
Hello, I am having the same issue on an Iphone 7, anybody knows how to restore Bluetooth? (WiFi is ok)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike Wynne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 204
