메인 콘텐츠로 스킵하기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
189 질문 전체 보기
New battery worked for 3 days then it wont turn on?
I bought a battery from I fix it and installed it 3 days ago. Everything worked fine until last night when the computer wouldnt turn on. I tried everything… SMC Reset, Safe mode… all the hotkey combos, and the computer was just dark, nothing would happen.
Fast forward 4 hours and when I get home from work the computer works and I believe the SMC reset worked because it my clock was off and had to reconnect to a bunch of my accounts.
I’m not sure what the !&&* is going on but I suspect the new battery could be the issue because that’s the only thing that changed. I am currently using the old battery because the computer seems to work fine while charging. Anyone else experience this issue? My work is kinda cold, probably like 55 deg Fahrenheit so maybe that was the issue?
One more thing. when I first got to work and opened the computer, it took a second to wake up. I had to close the screen after pressing the power button, then opened the screen and it was working fine…. then I closed the screen and it stopped working for about 4 hours… I have 0 clue what happened.
Cheers!
Chris
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
Did you calibrate the new battery? Let’s take a better look at it using a better tool. Please run Coconut Battery and post you results.
https://www.coconut-flavour.com/coconutb...
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Mayer’s right also um you,..ok…this happened to me too and what happened was maybe you blowed the battery up or you bent the charging cable…Just saying…But listen to Mayer ;) ! Okay this is a edit now you where in cold weather or inside it was cold so I suggest that you don’t do that again and um well get another one or try to fix it but if it doesn’t work then Mayer we’ll probably help you
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Chris 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 23
