주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2498 질문 전체 보기
new battery won't charge
I replaced the battery with an ifixit battery. The battery showed 4% charge. I plugged it in and the charging icon lit. The battery kept discharging until the phone shut off. The battery won’t charge. When the phone is powered up thru a lightning cable the apple logo cycles on and off. The phone doesn’t turn on. I swapped the batteries between two 5 phones - the problem phone and a working phone. The problem phone now works normal and the working phone now does the same thing as the problem phone. Using two different phones eliminates hardware and software issues. Is it possible that the battery needs some type of “jump start” procedure to get it to charge? If so, what is that procedure?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
If you are experiencing the same issue on a known good phone with the replacement battery it is likely that your replacement battery is defective.
Try a different battery and if this doesn’t solve your issue move on to the charge port.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My thought as well. Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chuck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 28
