주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
466 질문 전체 보기
iPhone XR rattles when vibrates/ restarts constantly
My XR has been weird today. Before today sometimes it froze apps and it would fix in 3 seconds like normal. But today it has restarted many times. Installed the latest update but it still does it every 30 mins or so. It makes a weird noice (rattle) when it vibrates. I realize this could be a hardware problem. It accidentally fell from my pocket while sitting today but it wasn’t a major fall, could the rattle be because of that?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The rattle is likely because the screws that hold the hap-tic engine in place became loose after the drop. Also, if it has been restarting after the drop it is possible but unlikely that the battery connection is loose. The restart and freezing could be corrupt software. I would try installing the OS with 3uTools if you can. Furthermore, there may be an issue with the board itself.
  1. I would try to reinstall the OS using 3uTools if you have a windows computer. Try the retain user data first if that fails. Try complete clean install.
  2. Test a new battery
  3. If none of these options work send it to a qualified logic board technician
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Javier Velez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 1,814
