주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Greyish black screen with no Apple
I got home and I forgot I had my MacBook charging on the carpet . I came back and it was kind of hot underneath . I turn it on to find a flashing folder with a question mark . I shut it down and then boot it back up but only stalls on a black greyish screen with no loading prompt or Apple . I took it to Apple and the commands wouldn’t work . They didn’t really tell me the problem , only that they would have to do a repair . Help please !
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Yeah they told me something about the logic board but don’t know how to go about repairing it.
댓글 달기
답변 2개
선택된 답변
If Apple couldn’t give any answer with your Mac in front of them it’s pretty difficult someone can help over the net without any testing..it could be really anything that’s gone bad if there was prolonged overheating. I guess you have already tried the SMC and Pram resets, right ? In the best of cases, if resets didn’t change the picture, chances are pretty high you have a logic board failure. Do you have tools to access the inside to inspect if there’s any evidence of damage ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Yeah they told me it was something with the logic board but could it be also the ssd ?
I seriously doubt it's the Ssd, but try starting your Mac keeping the option key pressed..do you see anything appear ? Have u tried the resets ? People here are usually helpful but without info and feedback you won't get far..
I’ve tried every option you do on the key board . Everything started happening when I tried installing Kali Linux and configuring everything on a USB . Later on a got a corrupt file icon when resetting it and fixed it . Got it again and shut the computer down but only stalls on the black greyish screen
댓글 달기
Give it 5 to 10 hours is a cool place and try to turn it on again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Ok I left it alone for a couple days and no I see the corrupt file flashing
Can you open and see if it's wet inside or has water marks. If it's wet then try it and if it's dry you cant be sure what the issue is because anything can get water logged. In that case your going to have to repair each thing at a time until it works so good luck.
댓글 달기
귀하의 답변을 추가하세요
ashrockets 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
