주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
328 질문 전체 보기
How do I install airport card in Mac Pro 2006?
The illustrated installation airport is nice but not for the Mac Pro First Generation. I need to know which card (I have several) to use and how to install it inside the Mac Pro 2006 1,1 (OSX 10.7.5, 32GB Ram, 2 500GB HD’s, 2 750GB HD’s) I upgraded the CPU’s from the original dual dual processors (4 cores) to the Dual Quad Processors (8 cores) it works fine but unable to flash it to 2,1. See “Flash Firmware From MacPro1,1 to MacPro2,1 OSX 10.7
So It would be nice to see a guide for the installation of the airport card for the First Generation Mac Pro’s.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
필수 도구 키트
최고의 소형 키트에서 가장 유용한 도구.
지금 쇼핑하기
필수 도구 키트
지금 쇼핑하기
답변 1개
가장 유용한 답변
The best thing is to locate the Mac Pro Service Source manual which is floating out on the internet, as we don’t have a guide to install it
Here’s the needed part: Mac Pro, Intel iMac, ATV1 Airport card (2006) But this card only supports the older 802.11n WiFi standard.
Frankly, I would recommend you just use an external Ethernet WiFi hub so you can get a faster connection and full security (WAP).
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I did find some service manuals but nothing shows a "how-to" it assumes the tech already knows how... The part numbering is good thank you. I found a few on eBay (pretty cheap too) You made part of the answer! Now for some instructions on "How-to-Install" them.
Locate the connector on the logic board and just plug it in. You'll also need the antenna unit if its not present. Some very early systems don't offer the connector so if you have one of these theres nothing you can do internally.
의견 추가하세요
귀하의 답변을 추가하십시오
Michael Inman 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 88
