주요 콘텐츠로 건너뛰기
오랫동안 기다려온 인기 MacBook Air의 참신한 업데이트는 Intel Core i5 프로세서, Retina 화면 업데이트, 그리고 기타 수 많은 변경 및 업데이트를 포함합니다. 2018년 11월 7일에 출시되었습니다.
149 질문 전체 보기
How does the 'hardware microphone disconnect' on clid close work?
Does anybody have an idea how the lid-close hardware microphone disconnect is physically implemented?
Is it a switch in the hinge that disconnects the audio cable? Is it a pin from the lid sensor that goes from high to low that then pulls the digitised audio signal to zero?
Ref: https://www.apple.com/mac/docs/Apple_T2_... (p.13)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I haven’t put my hands on the new Air but I doubt it will work much differently than other Macs. Lid closing causes a sensor in topcase being activated by a magnet in the lid, a pretty simple and efficient mechanism. When sensor is activated the system is instructed to change power state and go into sleep mode and in most modern machines, if I remember correctly, after 3 hours into hibernation mode. The change of power state implies that a set of power lines (all S0 lines used by the Pc up and running) are switched off and get no power from the system until the lid changes sensor state again. Hope this is the info you were looking for..
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Henk Poley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 122
