Early 2009 Display Assembly on Mid 2009 system
Hi,
I was wondering if the display assembly from a late 2008 to early 2009 would fit on my Mid 2009 MacBook Pro 15” 5.4.
The connectors seem to be identical.
Thanks for your help :-)
좋은 질문 입니까?
Hi,
좋은 질문 입니까?
Arne Büsing without knowing the actual panel number and only going by the information you gave us it looks like it is compatible with the following:
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Early 2010
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
Your panel should be one of these models
LP154WP3, LP154WP4, LP154WE3-TLA1 or LP154WE3-TLB1 if so, it’ll fit.
해당 답변은 도움이 되었습니까?
Hi oldturkey03,
thank you for your answer. I apologize for not providing more Information.
the Partsnumber of the assembly is, as far as I know, 661-5091. the serial # of my MBP is W894201E7XJ
Thanks !
Arne Büsing looks like the full assembly is only compatible up to early 2009
Your machine is the
Apple MacBook Pro "Core 2 Duo" 2.53 15" (SD) Specs
Identifiers: Mid-2009 15" - MC118LL/A - MacBookPro5,4 - A1286 - 2324*
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 132
댓글 4개
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
Dan 의
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
Dan 의
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
Arne Büsing 의
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
Dan 의
