주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s battery stuck at 100% after u2 replacement & q2 jumper
Hello,
i had a family member's iphone 5s that has been used with a bad charger for a long time. The phone would not charge/start if battery was completely dead, and when a full or partially charged battery was placed,the phone would start and accept charge but would discharge quickly after that on its own.
So i ordered a new U2 IC chip and replaced it.
U2 replacement worked fine and the phone would start with a charged battery BUT would not detect the charging cable at all. I think in the process i chiped/damaged the Q2 chip.
So i removed the old Q2 chip and put a jumper in the 3 contact points.
Now phone boots up normally and it detects the cable and charges up fine.
The problem is the battery level reports 100% all the time until it actually runs low after hours(lets say the true percentage is 15%) and starts counting backwards from 99% down to 1% and shuts down.
If I plug the charger in, lets say at 4% ,the percentage will normally start going up until it reaches 100% and stays there, until low-battery of course.
What could be the problem? Could it be a bad q2 jumper? I luck the microscope to see if all 3 points are connected ok, but phone works and charges so I guess they are fine...
Could it be a battery problem or maybe some u2 contact points that haven’t been soldered ok?
What part of the phone is actually responsible for measuring the battery percentage?
Notes: The battery I used was a completly new one.
I put a youtube video to play(and test the battery) and played normally for about 5 hours until it shutdown.Seems normal battery life to me.
I am in NO way professional but i like DIY stuff.I only have a cheap hot air gun and a cheap soldering iron but i luck the microscope for precision.
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
That is the problem of SWI line see resistance near battery connector might be open.This SWI line is connected to Tigris then CPU.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ermm, as I said before I am inexperienced with this kind of stuff, might I ask for a more fool proof explanation? I don’t know what or where that SWI line is exactly on the pcb to check it. Maybe a picture?
댓글 달기
귀하의 답변을 추가하세요
Konstantinos Thanaselos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 254
