주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Why doesn't my home button and touch id work?
I’ve replaced my iPhone 7 battery with the ifixit repair kit. However after this repair my touch id and home button stopped working. I’ve already checked my connectors and ribbon cables on damage a couple times and I can’t find anything. I also checked my home button connector and cable itself on the lcd. However all of this doesn’t seem to fix the problem.
Also soft resetting the device is something I’ve tried so far.
Does anyone have a solution to this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If your home button was working before you changed the battery and you didn’t remove the home button from the screen the most likely explanation would be a really fine tear in the home button flex. It might be hard to see but if you could put it under a microscope I am sure it would reveal itself. I am not sure if iFixit supply the home button flex or not.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Check the circuit board components around the home button and battery connector. Sounds like you might of dislodged or knocked something off the board. Check for missing caps etc.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Dries Van de Velde 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 59
