주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
313 질문 전체 보기
Can I change my logic board originally in 2014 early to mid 2012's?
I have a old laptop which is 1.4 Ghz and 121 flash storage. Recently I would like to buy some 2012 8gb 2.0Ghz logic board to replace the original logic board. Is that doable and is there any recommendation or advice?
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
hi
just so i understand correctly, your are wanting to downgrade from 2014 l/b to 2012 l/b?
댓글 달기
답변 1개
선택된 답변
From what I can tell from your post, it’s sounding like you have a 2014 MBA and would like to install a 2012 Logic Board into it.
If this is the case, it will not work. They are completely different boards and are not compatible. The 2013 - 2014 board is what you want. I believe a 2015 - 2017 boards should work fine too, haven’t had a chance to test this personally though. (Upgrade MacBook Air A1466 i5 2013 logic board with a newer one 2015)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Alex Lupu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 68
