Moving Lines (marching ants)
From left to right I’ve noticed a series of lines roughly spaced 1cm apart across the entire screen. These are not consistent but more like moving pixels that look to be moving from the bottom of the screen to the top, they’re really faint however having noticed them its now something I can’t not see, any ideas? is this a sign of impending death?
좋은 질문 입니까?
댓글 7개
Can you take some pics or a short vid and post them here for us to see 기존 질문에 이미지 추가하기
Dan 의
here you go dan :)
jack crowther 의
Sorry I don't see the lines, the vid is a bit blurry which could be hiding it.
Take some stills at the highest resolution and you might want to use a stack of books to help steady the iPhone.
Dan 의
struggling to upload images for some reason but looks like this
https://www.youtube.com/watch?v=ozX3RmgM...
jack crowther 의
OK I see the issue!
Let narrow down possible sources of the issue
First do you see this on other external monitors? If you have an iMac do you see it on the iMac's screen as well? What is your system and the video board?
Are you using a surge suppressor which both the system and the display are plugged in?
Have you altered your systems config in any way?
Does this effect come and go?
Dan 의
댓글 2개 더보기
